I need to know when upgrading my ICS smartphone?
Number not found the IS on the list of post http://talk.sonymobile.com/message/199753#199753
My number is 1255-1126 model SI WT19a
Necesito saber cuando se actualiza mi smartphone a ICS?
no encontre el SI Number en la lista del post http://talk.sonymobile.com/message/199753#199753
Mi numero SI es 1255-1126 modelo WT19a
I don't have a suggestion on this, sorry, I'll let you know if I find something regarding this
If you find your SI in the released software table the software for your device is released and available in PC Companion and Bridge for Mac where you can update your Xperia™ Smartphone.
We will continue to add items in the list as soon as they are released.
We will however not be able to answer on questions like: "When will SI number XXXX-XXXX be added to this list?" or "when will country X get the update?"
If you don't want to wait, there's an alternative
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
thanks
update a week ago with flashtools to ICS but I have a problem with the display of the application of facebook, but making him fix a downgrade to 2.3.4 GB, let me know if you install this ICS I will have the same problem?
remember that if you are locked to a network it's up to them to release the update, you might want to contact them
can you elaborate on the issue? and remember that if there's an issue with an app the problem it's not Sony's fault but the app's developer
the application works perfectly in other phones in ICS 4.0.4 and 2.3.4 live-walkman, but in live-walkman with ICS 4.0.4 works with visualization problems
