Hey My mobile is xperia p i have a very big problem my i tipped my pattern false then i pressed the turn of button and the left volume up button, now my if i turned my mobile on it's starting to restart plzzz help me
You need to run a repair on your mobile - Use either PC Companion or SUS found here - Remember that your phone needs to be switched off and then when asked hold volume down and connect your USB cable
