What is awake in battery usage?
nishan256
profile.country.RO.title
_alexdon_
I suggest you disable the antivirus,it is acting up,that is my guess.Just disable it and see how it goes.
alexdon
15 REPLIES 15
_alexdon_
I do not understand what you mean,you have a good battery backup.Are you using task killers or battery savers?
alexdon
nishan256
In screen off time also phone is awake. Is that cause to drain battery? and why phone is awake when screen is off ?
Sorry for may bad english
nishan256
No i don't use task killers and battery savers
_alexdon_
Probably the network is causing it to stay awake,to keep signal when it is weaker.But you have a good battery life,considering you have not charged for almost 3 days.Or you kept it all this time in airplane mode?
alexdon
nishan256
I kept it in airplane mode to save battery, I want to know why blue awake bar showing when screen turned off?
_alexdon_
Can you post the list of apps draining battery?Is the screen first or the android os?
alexdon
nishan256
_alexdon_
Yes,there is an app acting up.What is that e in the left corner?What other apps do you use?
alexdon
nishan256
That's eset mobile security app other apps i use are radio, walkman. In cached processos there are some apps i don't use. some of them are cut the rope, pierre tolking parrot. in running process there are two app named google play sevices. that all
After re starting phone also appears them
