UK Xperia j wont work in Canada
max1960
Hi moved to Canada from UK and wondered why my new Xperia J wont work with a Canadian sim card any advice as phone was expensive and dont really want to buy new one cheers
max1960
OK Thanks everyone
14 REPLIES 14
Jake-SonyXperia
Hi max1960,
With the information provided, I can advise that not all handsets are going to work on all networks. You may want to check the white papers for the Xperia J device you have and then clarify with the Canadian Network carrier if the frequencies the handset use work on there network.
White Papers: http://www.sonymobile.com/global-en/support/phones/xperia-j/support-documents/
I hope this information helps.
What are your thoughts about this forum? Let us know by doing this short survey.
Thommo
Genius
As above but it could also be that your phone has a lock on it
Dial *#*#7378423#*#* then open Service info then SIM lock - Post results back
max1960
here are the results
network 0
network subnet  0
service provider  0
corporate  o
sim   0
profile.country.RO.title
_alexdon_
It is locked.
alexdon
max1960
Thanks. How do I unlock it ?
Jake-SonyXperia
Hi Max1960,
The information you supplied above means the device is not locked, the device would show 5 on the network section if the device was locked.
You would also be shown a message to input a code to unlock the device when you inserted the SIM card from another network.
This sounds more like a frequency issue. I suggest using the white papers as stated above and contact the network carrier.
Thommo
Genius
If your phone reads like below then your phone is locked as can be seen by [x] and cannot be unlocked even with a code as the 0 means no tries left to enter a code
[x] Network 0
[x] Network subset 0
[x] Service provider 0
[x] Corporate 0
[x] SIM 0
Now if it reads like the below then your phone is unlocked as there is no x in [ ] and the 0 means you don't need any try's to unlock as it already is
[] Network 0
[] Network subset 0
[] Service provider 0
[] Corporate 0
[] SIM 0
_alexdon_
Now it makes sense.I knew something but I was not sure,but now it is clear.
alexdon
max1960
What is your advice then is there any way of using this phone in Canada? Can I get it unlocked? If it is a frequency problem can I change the frquency?
