Hi !
So, I have a Xperia mini and i want to know if there is a theme or anything that we can put in the xperia mini to be equal to xperia x10 mini at the text..
I like this blue one than the grey of my new xperia mini..
try this
http://forum.xda-developers.com/showpost.php?p=8719846&postcount=10
try this
or
http://forum.xda-developers.com/showpost.php?p=14501689&postcount=15
or
http://forum.xda-developers.com/showthread.php?t=930831
How to sideload apps
1st Method
How to install it
You need to
download IO File Manager
download the app on your computer, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
2nd method
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
3rd Method
BOX and upload the apks from any computer
install the App on your phone -> open BOX -> tap on the app -> install it
4th Method by far the easiest
an even Easier alternative
download the app, transfer it to your SD card
Download Apk Manager
https://market.android.com/details?id=com.magmamobile.app.apkinstaller&hl=en
open "Apk Manager" and voila select the apps that you wan't to install
