The Weather Widget: How do I change my location?
Astralogic
Hi, I just got my Xperia T and I'm loving it!
The problem is the waether widget thinks I'm in london but I'm not ๐Ÿ˜• How do I change it?
Thanks
Astralogic
xazorx
You might want to go to the normal settings, and turn off locationservices. This could confict with the widget.
5 REPLIES 5
xazorx
If you tap the wheather widget, a menu will appear, and if you look in the right corner you will see a small round button with two tools in it. This is the settings menu for the widget. If you tap the icon, you can choose location, and whether you want to use Celcius or Fahrenheit. And some other features.
Astralogic
The location setting is greyed out and I can't change it Slightly_frowning_Face
xazorx
BonnieBal
I am using Xperia Z1.  The weather widget shows me in Washington DC - incorrect.  I keep changing the location to the correct one, but the correct location doesn't get saved.  It just keeps reverting to Washington.  How can I "save" my correct location?
Kimkeogh
Thanks
Astralogic
