Hi there,
Repair/re-install the phone software using Sony Update Service and check if the problem persists.
Make sure that the battery is charged at least 60% and if you want to backup your important data, read this topic:
Cheers.
Hi there,
Cheers.
You can also take a look at the following topic:
Thanx very much, the problem is no more.
