(Sony xperia)two words appears again and again..after press power button
mentholprose
Hi IM Bangladesh have updated 4.0.4. And that more days ago. About 2 to 3 monotonous from three days ago I turned my Bluetooth on and then my XPERIA MINI PRO SK17I Is continuously arraignments I press the power button then  firstly,appears Sony and then expire. After this it's running....Running Till open the battery plz:smileyd_oh:help me................
Spoiler
Repair your phone with
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
9 REPLIES 9
PC Companion (PCC)
Bridge (for Mac)
mentholprose
. solved.
though I have updated 4.0.4 but with your prescription I have downloaded sus and reupdated.and its worked.
thank you so much.:smileyhappy:
Anytime
MRneoV
hello there..i'm chung sheng here,my xperia neo v also facing the same problem.. I downloaded SUS and PCC but my problem is SUS doesn't have my phone model and the PCC can't detect my phone because it keep restart after showing the two word which is sony and xperia..help~~~
profile.country.RO.title
_alexdon_
For SUS,run it in compatibility mode with windows 7.
alexdon
MRneoV
i currently using window 8.1...would you mind show me how to run it in compatibility mode with windows 7? Thank you so much for reply 😃
_alexdon_
Right click-properties-compatibility tab-tick run this program in compatibility with-select windows 7.
alexdon
MRneoV
okay...do i need to restore factory or just update the software?
_alexdon_
You said you wanted to update in your first post.If you update,nothing will be lost.If you repair,phone memory is erased.
alexdon
