Hi friends, I android phone android 2.3.4 to 4.0.4 upgrade with PC Companion software, but after a while the phone was working too slowly. 4.0.4 I installed the android again with the Sony update service. Some features have no such options on the camera shooting mode landscape, sport, such as fast. Logs \ Filter at the sim card options.
I want to install the original rom.
Sony Ericson Xperia Neo V of this message to my phone in Turkey by one user wrote.
yep neo v is a bit laggy after the ics update..about the camera
ur camera is most probably running in the scan auto mode..switch it to normal mode..
1st go to the camera app and touch the screen once..
u can see scn-auto on the upper-right corner..
touch it and switch to normal mode..
now another option appers at right side of the normal mode..
their u can see landscape,sports etc mode..:)
meanwhile u must have a look at this thread...http://talk.sonymobile.com/message/252997
Well Logs \ Filter section Where can I find the SIM recording option?
please be a little more clear about it..(never heard of this logs/filter section in smartphones..)
however saving messages to sim option is there in the messages->settings->sim messages where you can manually select the messages you want to save to sim..:smileyhappy:
Logs --> Filter --> SIM Registration (Filter contacts) on the SIM Registration
I had a choice. I chose that option, and direct to the SIM card when your SIM clerks was recording a new person.
so is the matter resolved..?
and uh..:smileysad:.. sorry can't find the option in my phone..
but i'll try to forward your ques to the forum moderators and will tell you how to do it if i can find a solution..
Yes, I would be glad indeed. This topic has started to squeeze my life.
Can you elaborate on your issue, are you trying to save your contacts to your SIM card? are you trying to extract your contacts from a SIM card? are you trying to repair your phone? do you have a custom ROM and you want to flash the original firmware?
