In general, such a problem ... gps enabled and is not run applications that use it all right, but once you launch any application that tries to determine the location of 30 seconds after the screen goes out and goes to the phone restarts ... anyone any ideas?
I think it's time to go for Z3+...
It just happened with my phone too.
I have been struggling with the same problem for two weeks. Any time an app uses GPS to find my location, the phone resets. I have found that if you open "location services" in Settings, and uncheck the box for "GPS satellites" the phone will continue to work when using navigation apps. But of course then you cannot use GPS, so it is not an acceptable permanent fix.
If many are having same problem, it just cannot be all of us have done the same mistake together, it probably should be related to the software or the Hardware. Hope Sony can help us out.
Regards,
Samson
Hello,Have the same problem.
I was using GPS very often,but saddnely my phone after enabling any gps software was rebooting.It started about 1 month ago,please any one help us to solve this issue,I dont want to but new phone!!!
I have the same problem with my Xperia Ion. I tried update through PC Companion, Factory reset and after all when start an application which uses GPS the phone is restarted.
Any help is appreciated.
I have encountered the same problem with my Xperia Ion.
Even I have tried to check the GPS with flight mode ON and my ION did not restart but the GPS is of little use with flight mode ON.
But atleast this proves one thing that, the Hardware is perfectly fine, the problem should just be a software one.
Hope Sony steps in, after all this is sony's forum right???
Regards,
Samson
I am using Sony Xperia Ion LT28h Android 4.1.2 Build:6.2.B.0.211, when GPS on the Phone automatically restaring, I am Repair in PC Companion, but same problem repeating, please give me suggestion, GPS is every important for me
