Shortcut problem when connecting to pc
Hello, i am really annoyed with how the timescape handles the shortcut, everytime i put my xperia into computer and plug it out, shortcuts which are installed in the sdcard always gets deleted. I used the "arrange my own order" in the menu, but it always gets rumbled up everytime i plug it in/out.
I also used to put now my shortscut in the homescreen, but shows the same problem.
i have many apps in the sdcard, and also because i cant install in the internal memory because of like just 100MB space.
any recommendation?
That's odd that you have that issue with that build number the latest build number is 4.0.2.A.0.62
7 REPLIES 7
You probably have an old firmware. btw the issue is not timescape
go to settings -> about phone and check your android version and Build number
Use SEUS to update your phone
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
Make sure you backup everything
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
How to sideload apps
1st Method
How to install it
You need to
download the app on your computer, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
2nd method
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
3rd Method
BOX and upload the apks from any computer
install the App on your phone -> open BOX -> tap on the app -> install it
4th Method by far the easiest
an even Easier alternative
download the app, transfer it to your SD card
Download Apk Manager
https://market.android.com/details?id=com.magmamobile.app.apkinstaller&hl=en
open "Apk Manager" and voila select the apps that you wan't to install
oh i see, its 2.3.4 and build number 4.0.2.A.0.42. is this firmware shows this behavior?
thanks!
Anytime
