Hi all,
I got stuck in the sony ericsson logo when restarting. When i try to repair with Pc companion or SEUS it shows no updates available...
I did this repair before 2 times when problems occured.
Pls help me
if now you can always repair it with Flashtool
http://talk.sonyericsson.com/message/139700#139700
make sure that you mark the Correct & Helpful Answers
try w/o the SIM and SD cards
Thanks, but its not working. The exact words on error is "there is no software available for your phone yet. Pls try again later"
that doesn't make any sense, it should tell you that either you have the latest update or that there's an update if you have 2.1
Flashtool will work for sure
Pls check the below screen shots
in first i selected repair phone
in second i plugged in flash mode
in third it showing error.
pls help me...
don't use PCC
try
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
make sure to mark the Correct & Helpful Answers
Its just showing u have updated software but it doesn't repaired.
what i should for repair or reinstall 2.3. i did before but its not working now.
that is so bizarre, use Flashtool instead
Thanks working good...
