I have the app superuser by clockworkmod that I want to remove but don't know how. My phone is not rooted as I have checked with apps such as root check and other similar. To try removing it I installed Es file explorer and checked in the system/bin/ for su but couldn't find! Any help how to solve this probelm is very much appreciated.
just repair your phone with SUS or PCC that will be easiest way to do so
Update Service (SUS)
PCC? Do you mean the PC companion?
Indeed
Alright I am trying out ssu right now, thanks a lot for the help and hopefully this will work now.
it should wok
Thanks a lot once again for the help, works perfectly now just have to get the apps I actually want not. Kudos to you
anytime
