ray dialer connection problem - dialer hangs at 'connecting' screen
Hi All,
I brought a Xperia Ray this month, since then am in love wid the phone.
But i am experiencing a call connection issue some times.
Sometimes when i try to make a new call, the phones dialer screen remains stuck at the 'connecting' screen, and i cannot disconnect the call nor can i make another call attempt. i've to wait for some 4-5min till this dialer ends.
This same as http://www.youtube.com/watch?v=5NBXPJ0Kw5w
Has anyone of you experienced the same problem?
any idea what would be the solution...
Nabeel
repair your software and see if it helps
Update/Repair your phone via PCC OR SUS
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                 or
both the links are same
it would delete all phone data so backup
2 REPLIES 2
Nabeel
                 or
thanks for a quick reply!
Will do this and get back..
