Problems following Update
Hi
I have multiple problems since updating my phone ysterday through the Sony Ericcsson PC Companion
Everything was OK till midday today when all my contacts disappeared and the syncing stopped
Now if I try to read email, import contacts or make a call  from the call list I get multiple error messages including:
The application Contacts (process com.sonyericsson.android socialphonebook has stopped unexpectedly
The application Process com android email has stopped ........
The application process com .sonyericsson.eventsstream extensions has stopped ........
This seems like a really bad update and it has crippled my phone
It updated correctly and finshed normally with a re-boot so I have no idea what is going on
Anyone form SE like to explain waht's going on ????!!!
JMB
Nabeel
i suggest you to reflash your firmware,
Update/Repair your phone via SEUS or PCC
SEUS ( Sony Ericsson Update Service)  ... download it and install it on your pc and follow the on-screen instructions  http://dl-www.sonyericsson.com/cws/download/1/110/61/1323075336/Update_Service_Setup-2.11.12.5.exe
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.. Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
Don't forget to mark the Correct Answers and Helpful Answers
Nabeel
