Hy! I just updated my Xperia Arc S to ICS and i think i did everything that the PC Companion said, but after I finished everything and tried to turn on the phone after vibrateing (normally) apeard "SONY", but after that an exclamation sign in a triangle and a phone appeared (something like this: http://www.hardreset.eu/images/motorola_droid_hard_reset6.jpg) and the phone automatically turned off! I tried to turn on the phone several times, but allways the same gif appeard... What should I do?
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
or
