Problem with booting xperia s
Matheusew
After trying to update my xperia s to android 4 at about 3 times by pc companion my xperia s don´t boot, when i boot it only vribrates and appears SONY on the screen. It´s the first time i use the phone, i'm charging it now, but still only appears SONY on the screen. Any ideas?
Anytime Slightly_smiling_Face
http://talk.sonymobile.com/thread/44888
10 REPLIES 10
charge your phone (wall charger) wait an hour then use SUS instead
Update Service (SUS)
Matheusew
Ok i tryed after 30 minutes of charge but in the mid of process the download of update fail. I´ll try to charge more.
the issue is your computer or internet connection, turn off your firewall and antivirus also reinstall JAVA
Matheusew
I  can´t even charge my phone, the notification led is red when i charge but after a time he boot and reboot then back to red light. And the charger is not warming very strange Thinking_Face
Try this
connect your phone to the wall charger > press and hold the power button and volume Up for 5 seconds > let it charge for an hour, then try to turn it back on
Matheusew
When i press and hold the power button and volume Up for 5 seconds, nothing happens, and the phone is charging for more than 1 hour. But after a time it begins to restart for 1 minute and then back to charge (the led is still red) and i can´t boot or update  with SUS because the phone isn't charged Slightly_frowning_Face
just try my suggestion, if that doesn't work, and neither another wall charger or usb cable, the only option is to take it to a sony repair center or return it to the store
Matheusew
LOL My Xperia S has just ressurect. I let it charging on notebook via USB and went to the bakery, then when i back the PC Companion had repaired and upgraded it. Now it´s with ics and can be normally charged. I just let it plugged on notebook and the PC Companion did all the work. Thanks at all.
