hi i tried rooting by xperia u st25i, ics 4.0.4, build-6.1.1.b.1.54 using flash tools but i keep getting this error- please help
21/052/2013 12:52:25 - INFO - <- This level is successfully initialized
21/052/2013 12:52:25 - INFO - Flashtool Version 0.9.10.1 built on 2013-01-09 19:49:47
21/052/2013 12:52:25 - INFO - You can drag and drop ftf files here to start flashing them
21/052/2013 12:52:37 - INFO - Device connected with USB debugging on
21/052/2013 12:52:38 - INFO - Connected device : ST25
21/052/2013 12:52:38 - INFO - Installed version of busybox : N/A
21/052/2013 12:52:38 - INFO - Android version : 4.0.4 / kernel version : 3.0.8+ / Build number : 6.1.1.B.1.54
21/052/2013 12:52:41 - INFO - Pushing C:\Flashtool\.\devices\ST25\busybox\1.20.2\busybox to /data/local/tmp/busybox
21/052/2013 12:52:43 - INFO - Pushing C:\Flashtool\custom\root\subin\Superuser\su to /data/local/tmp/su
21/052/2013 12:52:43 - INFO - Pushing C:\Flashtool\custom\root\subin\Superuser\Superuser.apk to /data/local/tmp/Superuser.apk
21/052/2013 12:52:46 - INFO - Pushing C:\Flashtool\custom\root\AdbRestore\RootMe.tar to /data/local/tmp/RootMe.tar
21/052/2013 12:52:47 - INFO - Now open your device and restore "RootMe" backup. Waiting ...
21/052/2013 12:52:47 - INFO - You have 60 seconds to follow the restore advice
21/052/2013 12:52:47 - INFO - Running adbrestoreexploit
21/052/2013 12:52:49 - INFO - Restore worked fine. Rebooting device. Please wait ...
21/053/2013 12:53:08 - INFO - Waiting for device
21/053/2013 12:53:11 - INFO - Device disconnected
21/053/2013 12:53:33 - INFO - Device connected with USB debugging on
21/053/2013 12:53:39 - INFO - Root hack did not work.
21/053/2013 12:53:39 - INFO - Cleaning hack files
21/053/2013 12:53:39 - INFO - Rebooting device. Please wait.
21/053/2013 12:53:46 - INFO - Device disconnected
21/054/2013 12:54:08 - INFO - Device connected with USB debugging on
21/054/2013 12:54:10 - INFO - Connected device : ST25
21/054/2013 12:54:10 - INFO - Installed version of busybox : N/A
21/054/2013 12:54:10 - INFO - Android version : 4.0.4 / kernel version : 3.0.8+ / Build number : 6.1.1.B.1.54
You see what i wrote above ?
You don't have to be in a fastboot to flash a stock kernel.
See reply number 1, how to root xperia u go sola
Well well well, PLEASE do a search before posting
Here you go btw
first flash b.10 kernel
then root
then flash b.54 kernel
can you tell me how to do this because when i go to fastboot mode to flash the kernal it says i have to be rooted but to root i need to have this kernal ???
thanks this worked earlier i had downloaded .elf kernals which i had no idea about anyway thanks
