My new phone is a Xperia arc s (with gingerbread). All my phone calls are interrupted after a few seconds. Anyone has an idea about this problem ?
thx
See if software repair helps
Update/Repair your phone via PCC OR SUS
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
Feels like an issue of 3rd party app.. Could you go through all the apps such as task killers, juice defenders, battery manager, etc etc ( same kind ) and revise their settings
Try uninstalling all such apps and see if it made any difference
If not then factory data reset your phone . Be aware it will erase all data on your phone so backup
Hi Nabeel,
The phone is brand new, I havn't installed apps on it. I am testing phone calls since this morning.
The only setting that I have added is to add my google account.
I hope it isn't hardware problem ...
or
Do you have any third party case attached to it at all?
No, I havn't any third party case.
But my problem is solved thanks to Nabeel proposition :
Since this morning the phone calls aren't interrupted.
thanks to you & Nabeel
