no audio on mp4 file
I need help on this please..
I want to watch movies on my xperia s, tried to download mp4 movie from torrent to my laptop and transferred it to my phone,
the video is so so good since its an hd video but there's no sound... tried to download 2 mp4 movies ( UP and real steel ),
but both have the same problem... what do i need to do... pls pls help...
as005
*Remember to switch to Software Decoding when using MoboPlayer, Only then it *might* play the sound.
Or Simply Use DicePlayer...That would play sound easily.
11 REPLIES 11
Nessa
Have you tried to download another video player from the Play Store?
unfortunately, no..
can u recommend a good video player that is free on the Play Store?
thanks in advance!
Mobo Player
if it comes to worse download and install (on your PC) formatfactory -> then use MPEG
ill check that.. thanks for the reply.. il give u updates asap..
Anytime, It should work but let us know if it doesn't
as005
Dr_Chris
http://mediago.sony.com/enu/features Alternatively, you can transfer the video from PC to phone via Media Go, as this will sort out any coding incompatibilities.
I tried the Mobo Player but unfortunately it didn't work, tried to do the
software decoding but stil ddnt work
