Hello,
My phone neo v is not starting up what to do pls tell me.
i had unlocked the bootloader.
no custom roms was there.
i can only boot cwm recovery.
pls tell what to do.
it isnt booting no logo of sony erricson .
pls tell what to do
leave all
calm down,,, have water and then proceed
forget all what i wrote above
just foloow the steps now
1- download this http://sourceforge.net/projects/seandroid/files/xperianeov/Firmwares/NeoV.4.0.2.A.0.62.rar/download
extract this file using winrar
2- download flashtool http://androxyde.github.com/Flashtool/
3- install flashtool and after installing go to you C: DRIVE and > flashtool,, > firmwares> delete all the files present here > and copy the extracted file ( from point 1)
4- Run flashtool > click on flash > flashmode > it will show your firmware on the left > select it > click ok > it will prepare files > will ask you to connect your phone > do it > install it,
thats it,, step by step guide i gave you...
do this and ask anythin , i am online
leave all
thankx u r very nice
ohhh thats great mahn :smileygrin:
thats callls for a partyyyy :smileygrin:
the firmware which you downloaded, keep it safe for future as well
here is how to relock bootloader
1- download this, http://www.mediafire.com/?g1b5j712ajx4yjd
this time you don't have to extract it its a .tft file
2- and then same process ,, put it in firmwares folder and flash
again come back with good news
Hi Nabeel,
I installed and rooted ICS as per ur post and now im experiencing some issues like Wifi not connecting, system reboot etc.., I wanna go to Ginger bread now. Before that, I 've a huge data in SD card for the HD games, RS 2012 and SIx guns. I dont want to lose the progress. So, I know i can use the above method to go back to GB. But, what 'batch' mode should i use to back up all these progress in games and other settings in phone in Titanium backup. I also have CWM installed and took one back up already of the current rom
Also, once i go back to GB, i m planning to use the pandemic rooting guide (which will flash .42 firmware, root it and then upgrade to .62 firmware) http://forum.xda-developers.com/showpost.php?p=21912336&postcount=1. Do u think thats a good idea to root. Or is there any other easier way to root .62 firmware and have an option to unroot as well.
And do these flashing and software updating often(which is erasing all data again and again) cause any damage to the phone.
Message was edited by: senthilrameshjv
Does it safeguards the phone memory data - the contacts-SMSes.??
Nopes, all data will be deleted
My Phone doesn't get detected by the Computer using USB. will the above still work?
You need to be a little more clear with that.
I don't know what you're trying to do . So explain me everything and I'll try my best to help you sort it out
i know this is a neo V thread but i am posting a question here for neo L
my neo l just turned off by itself and now it wont turn on.
when i try to turn it on it just vibrates but nothing comes up on the scree.
i tried updating the software using SUS but the problm woudnt solve
it was in stock ROM.
