Hello.
I have a Problem with my Sony Ericsson Xperia neo V!
I wanted to take a picture with my frontcamera. I opened the camera, wanted to choose to frontcamera, but i can't find it. I searched on google for solutions, but i dont found one. My brother has a Neo V too, and there i can find to choose to frontcamera. I already touched on "SCN Auto" but there i cant change to frontcamera..
Android-Version: 4.0.4
Kernel-Version: 2.6.32.9-perf BuildUser@BuildHost #1
Build-Number: 4.1.B.0.587
I suggest you try a repair via sony update service:
If this does not work,visit a sony service:
Try settings-apps-all-camera,clear data and force stop.Restart your phone and check in camera again.
It doesn't works..
Go to the camera app,select normal mode and after that select front camera.
Still doesn't works.. When i changed to normal mode, the button for change to front camera still isn't there
I've already repaired my device via sony companion..
i will contact the sony service.
Keep us updated.
I too had the same problem when i purchased the mobile, the front camera switvhing option is not appearing in the camera app and when i took it to the service center they told that the software needs to be reloaded. But even after the software was reloaded the same problem persisted. Then after a detailed study they told that the board needed replacement and they replaced it after 15days. But now i have got the same problem again. Can anybody say why this problem is occuring again and again.
