My Xperia U doesn't work
liston93
Hi, I have a Xperia U by a little over a month and I like it really well.
A few days ago, while he was turning off it freezed so, probably making a mistake, I removed the battery and from that time it doesn't work. This morning it gave some sign of life because, while yesterday would not turn even a small light, when I attached to the PC is switched on the red LED, which remains fixed.
I wanted to know if there is a way to bring it back to life, or if I have to be to get it repaired.
Thanks
p.s. sorry fot the bad English, i hope you understand otherwise.
liston93
I tried to do it, but nothing..
I've contacted the support, and said to me to go to an assistance point.
Thank you everybody for all your answers Slightly_smiling_Face
6 REPLIES 6
johnybravo_1981
english please
Arnab
Enthusiast
repair it using sony update service.
liston93
I follow the istructions but nothing happens Slightly_frowning_Face Only the red led works Neutral_Face
johnybravo_1981
what error u got?
Arnab
Enthusiast
this should not be the case, try to plugin the mobile in switch off with volume down pressed as instructed and it should work always.
liston93
