Hi guys,
My proplem is like this : First, when I bought my Xperia Play(4 months ago)my home network WiFi worked very well on it but today when I search for wifi network I just can not find it I checked my laptop: the WiFi was working very well and I checked my family phones (Android and Iphone) and also they are connecting and working.
I tried to do the next : 1- turn off and on my modem (I think it is called like that, I am not that good in networks) but nothing happened
2-turn off and on wifi on my phone
3-turn off and on my Xperia Play
4-Uninstalled go launcher
last things I have did before this happened :
1- Installed a game from the market that uses WiFi called : The Sims Free Play
2- Installed go launcher and go locker with ICS theme
More information : when I go to my WiFi settings I see that IP address is Unavailable.
I hope that you help me I really can not use my Xperia Play without WiFi and thank you.
I hope also that you explain step by step because I dont know much about networks, thank you
uninstal go launcher... restart the fone n thn try... hope it helpz
thank you! but I missed that game
you'r welcome
hi, i don't know either i getting the same issue with u or not.
is it your wifi is locked with security key? if yes, then try to disable the security 1st, to test your phone wifi either can connect with your modem or not .
if you can connect in this condition, i think you must reset your 'WEP Key Length'
"For 64 bit keys you must enter 10 hex digits into each key box. For 128 bit keys you must enter 26 hex digits into each key box. A hex digit is either a number from 0 to 9 or a letter from A to F."
hope this can help you.
