Is this headset fully compatible with xperia U?
I like it but we don't have it in Croatia as far as I know so I would ask a friend to get it for me.
I need to know if everything will work; remote, mic...?
I'm a bit confused about those standards and I know Smart headset works with 2012 series, and Livesound doesn't...
so what about Music Lover's Kit MK200?
http://www.sonymobile.com/global-en/products/accessories/music-lovers-kit-mk200/
Ahhhh, I found the answer!!!
Apparently there's a small converter cable that we can use to make the headset work.
it won't work with the 2012 Xperias (Xperia S, U, P sola, acro s, gx, sx, etc), it will work with the 2010 and 2011 xperias
Thank you for your answer.
Are you sure though? Is there anywhere that we can check which standard that headset is?
I found them on T-Mobile site marked as accessory for Xperia S.
Also, Sony posted on Google plus a picture with this headset plugged into one of the new phones.
https://plus.google.com/117586446271921149656/posts/9poLrVecqFm
I can see they are supposedly compatible with the earlier phones too, so that's why I'm confused.
