Hi all
does the xperia arc have funcion to minimize opened aplication and later maximize
till now i haved nokia n95 with symbian and there is option to minimize, when push menu buton app is minimized and after if you push and hold menu button
you open window with minimized aplications
does arc/android have something like that
thank on your help
There is no function directly like this; however by pressing the home key on the handset it can minimize applications in a way, like the browser for instance pressing the home key will not restart the application so the last website is still present on the device. The same goes for some games and other applications but not all.
thank you jake
