I had Xperia mini ( ST15i ) Has overheating problem as soon as I turn it on and it happens always and every time .
My question is " Can I install ICS while my phone over heating ? And " How it is done ? Do I update while phone is turned off although capacitive buttons still interfering ? "
you can update to ICS (if your SI number is on the list), instead of PCC use SUS
Update Service (SUS)
-=[ Thanks A Lot ]=-
And yes my SI is on the list . So I update using SUS with the phone turned off and choose second option " Reset + Update " .
I hope ICS solve the problem .
Keep us updated
After I update my phone to ICS the way I said before , it still the same problem as soon as I turn on the phone the capacitive buttons are triggered continuously very fast I cant even unlock the phone or load home screen .
I am very sad ICS didn't solve my problem
take it to a sony repair center
Update !! I am now so happy , I finally get red of the problem . it was too weird , but my brother figure it out , It was not overheating as it happens when the phone is cool and as soon as the phone boots up , It was software problem made function of capacitive buttons being inversed , so when you don't touch the button it act like you keep touching it . and when you touch it and keep it touched it act like it is untouched . So after booting I kept cancel button touched until I make it to factory reset option and I used it . After reboot problem solved .
-=[ Thanks A Lot for Your Big Help
Factory reset + update was a good choice
Enjoy your ICS
I did choose Factory Reset + Update as you told using SUS but problem stayed , until I did Factory Reset on the phone .
-[ Thanks ]-
