i forgot my xperia go password lock screen. someone can help me ?
muhd_aliffffff
my phone cant detected on pc . i tried several ways but still cant solve this .
Tags (1)
Jake-SonyXperia
Hi muhd_aliffffff,
Welcome to the community,
You may need to use PC Companion to perform a software repair, as I am not confident that the Xperia Go was able to use the My Xperia function. However please try Uliwoolys instructions first, if that fails please use the instructions below.
Here's how to run the repair on PC Companion:
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
And Bridge for Mac:
2. On the Main Window select "Xperia > Repair Xperia Device".
3. Ensure the phone is charged and select "Ok" in the following window.
5. Wait until the initialising step is finished the continue as below.
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
5 REPLIES 5
Jake-SonyXperia
Hi muhd_aliffffff,
3. Start.
4. Repair Phone
5. Continue
7. Next
8. Wait for prepare
9. Select Phone
And Bridge for Mac:
muhd_aliffffff
phone connected with with computer but cant detect . have another ways ?
muhd_aliffffff
i tried and My Xperia cant found my phone
Jake-SonyXperia
When you connect to the PC, you need to make sure that the device is first powered off and second that you have gone through all of the steps first, you will not connect the device until the very end of the process.
