How to manually update 2012 Xperias to Android 4.0.4
Click on one of the topics
as always thanx XDA forum
Rooting "might" void your warranty. I'm not responsible if anything happen to your phone (nothing should go wrong,, if something do go wrong, just repeat the whole process).
you need to unzip the file
on service menu check the bootloader if it says unlock yes it's not branded to a network
I try to use the SUS and display a error message:
i dont understand why say that. i have only app from google play.
can help me please
you need to relock your bootloader otherwise you can't use SUS nor PCC
I wasn't aware you could do this till I read this thread. Worked perfectly - I used the same method to re flash an Arc S with a generic fw too.
Thank you
Please put the Sony update your Sony Xperia S modernize the Middle East, the type of device is my Xperia S (LT26) 1257-5183
Thank you
anytime
Enjoy ICS
thanks works great. but the google play is not working properly
thanks
How i can do it that??
