How to check if the bootloader is locked or unlocked?
MaddyArc
Hello Frnds,
I need to submit my handset for housing crack issue to the SE service center.. But recently I had flashed it with the Stock ROM prepared with the help of SEUS and Flashtool. So can anyone tell me how to check my Bootloader has been unlocked or it is still locked? Because the method to flash the Stock ROM I used says that it wont unlock the bootloader (as per XDA devlopers).. So can somebody please tell me how can I check it? Thanks.. Slightly_smiling_Face
slimshaddy
Hero
just try to update with pc companion or update service , if it says modified software then the bootloader is unlocked , if it still continues ( cancel it ) then it means its locked..
dial *#*#7378423#*#*
check tje device info..
10 REPLIES 10
slimshaddy
Hero
MaddyArc
It is accepting my arc without any problem.. Slightly_smiling_Face That means my bootloader is still locked.. Slightly_smiling_Face Can anyone tell me how to switch ON the proximity sensor? I checked the details under the Service menu, it is showing Switch OFF..
slimshaddy
Hero
its always on Slightly_smiling_Face
you have to move your finger over the sensor then it will change it to "yes"
try it..
the service menu is basically to test all the hardware of the phone , to see if all the things are working or not...
when you call , the screen turns itself off , this is because of the proximity sensor , when the phone touches the skin , it could end a call without you knowing it , so proximity sensor avoids this...
santam1
hey @slim I also have to flash my stock rom for the SEUS to repair my phone a long day back but I noticed in the service menu that it says bootloader unlock allowed-yes!! wud it cause any warranty problem???
slimshaddy
Hero
yes , i was going to add this info but dint want to confused him..
even if its says yes , its not allowed Slightly_smiling_Face
if you unlock it , you won;t be able to update from pc companion and \ or update service...
also , there are some DRM files  ( i don;t know what they are ) which are lost forever... so maybe some bad thing Dizzy_Face
santam1
uff....!!! thank's got relief for that info I thought my phone got bricked!!! neways but i've updated to .62 through my phone inbuilt update cntr!!! so ?? it seems fine na??? I mean got update and updated ??!!!:/
slimshaddy
Hero
yes its fine Slightly_smiling_Face i updated to 0.42 on the phone itself , so no worry... and i have updated to 0.62 just now Dizzy_Face
santam1
woohoo..thanks @slim....!!
slimshaddy
Hero
hmm Slightly_smiling_Face :smileygrin: Dizzy_Face
