hii.. battery problem
hey people... im currently using sony ericsson xperia arc running 2.3.4
after this update, there's a drastic drop in the performance of the battery of the phone Slightly_frowning_Face
i never had any battery problemms until now.. and when the phone used to run on 2.3.3, the battery was functioning just fine..
and now since ive updated around a week back.. ive been observing a fall Slightly_frowning_Face
and to my observation, i feel it's nt the problem with the battery but with the display.. when it ran on 2.3.3, the display would take around 35% of everyday's charge.. but now it takes EIGHTY !!!!!
please reply.. if u guys face the same problem, join me in appealing to SE.. and for those who dnt face this problem, please notify me as to where i can improve on the performance of the display.. i have kept the brightness to 15 % and the screen timeout to 30 seconds.. and within 5 hours the battery dies Slightly_frowning_Face Slightly_frowning_Face Slightly_frowning_Face and when i see the usage.. 80 % would be the display !!screenshot_2011-11-07_0015.pngscreenshot_2011-11-07_0016.png
slimshaddy
Hero
theres something wrong..it should not be that much..
update your phone again..
with this
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
and after update..turn off your bravia engine by going into settings > display..
keep me updated..
54 REPLIES 54
slimshaddy
Hero
with this
keep me updated..
hi kaiser, your battery ok now after updating again? i'm also having the same problem, display is using 70-80%.
hey thank u soo much for ur support and the link brah Slightly_smiling_Face
yeah ill update again n keep u informed after a 2-day trial Slightly_smiling_Face
and.. will the baseband version or anythng change?? Slightly_smiling_Face
hie keavze.. umm.. actually ive nt yet updated.. m outta station n will return after a few days Slightly_smiling_Face
so ill do it then.. n within da 2 days, if u update ur fone, please let me know of the improvements Slightly_smiling_Face
thank you !! Slightly_smiling_Face
slimshaddy
Hero
ok check it and do reply Dizzy_Face
well..., i've re-updated my arc again to 2.3.4, but the battery still the same. shows almost 80% usage.
so...what's next???
wokie slimshaddy :smileyhappy:.. now what.. keavze's prob isnt fixed..
keavze.. bad luck bro 😕 il try tomo 😕
slimshaddy
Hero
ok..charge it to a full 100%
then when around 15% remaining , go to settings > about phone > battery usage
and tell me all the items you get there , and the minutes used by it..ok..
did you turn off your bravia engine ?? and at what 5 do you keep your brightnes level ?
slimshaddy
Hero
hmm i replied to him. Dizzy_Face
