help & questions
saman
help & questions
Hello
1-Which of the following models are high speed?
sony xperia sl or  sony xperia v
2-Which screen is better quality?
3-Which is better quality camera and video recorder ?
7 REPLIES 7
saman
Hi
I did not notice much
Please answer all the questions complete
Hello
sony xperia sl 1.7 or  sony xperia v 1.5
There are other things that you have to take into consideration, Xperia S is the same as the Xperia SL, same CPU just clocked differently (1.5GHz and 1.7GHz)
BUT it seems that Qualcomm its not going to support the Xperia S's snapdragon S3 any longer, which means no 4.2 or 4.3 or 4.4
The Xperia V's screen its similar to the Xperia T's screen which has a different technology = slightly better quality but not a huge difference
As for the camera, check the other link so you can see pictures/videos taken with the Xperia S and V
saman
Hi
1-the quality screen TFT is beter or LED BLACKLITE LCD ?
2- Which of the two is stronger and faster CPUs ?
Qualcomm MSM8960 Snapdragon Dual-core 1.5 GHz Krait or Qualcomm MSM8260 Snapdragon Dual-core 1.7 GHz  ?
3- whate is screen  xperia sl  TFT or LED BLACKLITE LCD ?
4-Why not come for other models such as the Model SL  &  V  the new versions
But sumsung and .... for the older models give new versions android to provide users . but sony it does not respect the older models usersAlert
profile.country.RO.title
_alexdon_
1.My opinion is that LED is a little over TFT,even though both are LCD's.LED consumes less energy and has good viewing angles.
2.The MSM8960 Krait(S4) is newer than the MSM8260 Scorpion(S3),has a better GPU(Adreno 302 vs 220).Overall,it should give you better experience with your phone.
3.Xperia SL has LED LCD display http://www.gsmarena.com/sony_xperia_sl-4894.php
4.Please rephrase,I cannot understand the question
alexdon
saman
hello
4-Why not support sony older models such as the Model SL  &  V  the new versions software ( android) 4.2 - 14.1.G.2.257 and ....
But sumsung and .... for the older models give new versions android to provide users . but sony it does not respect the older models users:smileyalert:
saman
Hi
1-is Model SL the internal memory of the computer format and scan with antivirus ?
2-Can you create a  long password on the memory model SL ?
3-When connecting to a computer and copying operations ... Password request ?
4-Is there a program that will completely format the internal memory of  SL model
The  Can not return OR recovery to any method ?
