I know that many people already have probably started another discussion with the same problem.
Though the only answer i could find was the one that i had to flash my mobile , Which i dont want to do that :smileygrin:
Isnt there any fast way that i can just use one script and Root it fast and easy ? :smileygrin:
Hmm maybe you feel that way and and that's not wrong
Nopes you don't need to unlock your bootloader at all
Kernel is a very small thing, flashing it takes 3-4 seconds
You must wait though if you don't wanna be under any kind of risk
Thanks for the Guide but still this doesnt help me..
Im sure that sooner or Later there will be something that will just root 4.0.4 just like it was done with all other versions .
The you will have to wait
because at present there is no such toolkit
To be honest you are right my friend the thing is i find this way too complicated and also too dangerous (reffering to flashing kernel)
Still also i dunno if its correct to do that i mean do u unlock this Bootloader ? cause i heard if this gets unlocked i lose warranty right ?
Then im heading for that still i think im gonna mess it up
If you follow each step carefully then there won't be any problem...
For your info, flashing kernels are not risky
But you know rooting may also void your warranty
