Experia Go Screen draining power in standby and shows it is on in stats
OomBoom
Hi
I got my experia go about 2 weeks ago. The first charge the phone kept for 5 days and this is normal as my previous HTC wildfire kept between 4 and 6 days, I have everything of and also the power save on. I only use it to make and recieve phone calls.
Second charge was at 60% after 2 days and then in 8 hours it was dead. After a few charges since then it is still draining alot of power while in standby mode. It shows that the screen has been on for 90% of the time but it actually was on for about 5% of the time. When will this bug be fixed?
Power save is on and I am on the latest update.
OomBoom
Solution to power drain experia go.
I changed my background from an album photo to the normal experia backgrounds and now the phone looses about 15 -20% power in 24 hours.
Please have a look at this software bug and reply when fixed.
6 REPLIES 6
Henke
Please have a look at this thread and see if any of the tips might be able to help you:
http://talk.sonymobile.com/message/154243#154243
OomBoom
I am not sure if it was unclear but I have nothing on. Standby power safe is enabled. So phone is at best settings for power save according to Sony and other site tips.
My problem is the screen on time that is absolutly incorrect. Is this the actual cause of battery drain. Why did is keep 5 days and then all of a sudden 1 to 2 days with no change to useage?
Airbolt
Hi Henke,
I would like to know why there are so many RILJ partitial wakelock in Jelly Bean version, and keep system awake?  I had never seen RILJ partitial wakelock in ICS version. Because the system enter deep sleep with less time, the system could not save more power when in standby. Please help to inverstigate this issue, thanks.
OomBoom
Why is this assumed answered and how do I change it?
Henke
Regarding Assumed answered, please have a look at the Discussion Guideline and read about "Assumed Answered":
http://talk.sonymobile.com/message/1046#1046
OomBoom
