Hello.
I tried several times to upgrade my Android from 4.0 to 4.1, but every time it failed. It does not tell me how to solve it, just says try again later.
Could you tell me the solution please?
I have Xperia Arc X12.
Try this
Update Service (SUS)
there isn't android 4.1, it doesn't exist, the only android ICS available for Xperia are 4.0.3 and 4.0.4
Try this
is your SI number on the list?
http://talk.sonymobile.com/message/199357#199357
if it's not then you either have to wait or you can
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
Yes, I made mistake regarding the version.
Anyway, PC Companion told me an update is available. Then, I started updating my mobile using PC Companion, which failed in the middle.
Just now I used the SUS link you suggested and it worked. Could you please tell me why PC Companion failed?
And do you suggest continue in using SUS?
Thanks!!!!!!!!!!!!!!
PC Companion has a lot of bugs and it's not as reliable as SUS
Now that you have 4.0.4
Xperia S Music App 4.0.4 leaked, does it work with your Xperia?
http://talk.sonymobile.com/thread/38259
I think it is working. If I saw problems, I report it here.
Anytime
It is on the list.
