Dock mode?
RodLyman
Dock mode?
While awaiting the repari of my phone I'm trying to figure out different modes for when the phone i connected to the docking stations (DK25). Various images show the Xperia V in the following configuration. How do I achieve this? All I've managed up until now is the regular homescreen tilted on it's side and the SenseMe slideshow.
http://www.xperiablog.net/wp-content/uploads/2012/08/dk25-main-image-620x440.png
11 REPLIES 11
GoJohnnyGo
Rod,
There is a Sony application called "Smart Connect" that allows you to contol dock settings. If the app is not installed already, it is avail. at Google Play for free...
https://play.google.com/store/apps/details?id=com.sonyericsson.extras.liveware
Don't let the app intimidate you.  You will find many options available.  For me, I kept it simple, turning off most options.
John
RodLyman
Doesn't answer my question though.
I use Smart Connect for a lot of things. I keep a tag at work which adjusts appropriate settings. I use it with my wireless speaker and a bunch of other things. What I would like to know though is how I achive the kind of home screen in the pic above. I couldn't find such a setting in Smart Connect.
It's marketed that way so the function should be availiable, don't you think?
wasn't that supposed to be the UI when the phone was synced with a TV (when the phone was first released)?
as you can see your smartdock must be conneted to a TV through HDMI
http://www.youtube.com/watch?v=u_MHT2eR1dQ
http://www.youtube.com/watch?v=8M7Zj2cdKrg
RodLyman
This would explain some. I would question why they would market it with the same UI represented when the DK25 only charges and has no other connector. Not important of course but it seems a bit dishonest.
This does however raise the question if the UI shifts to this when connected wirelessly to a Sony TV.
can you post the source link to that image only charging w/ that UI?
on the official Sony link I don't see anything that it would say that if you charge your phone it will look like that
you already have the answer, you need to connect your phone to a TV through HDMI
ghia0127
where did you buy ur dk25?
