Display showing black white spot..
Hi, I'm frm Kolkata India...i'm using mini pro...
today i noticed that there is a small black spot showing at the bottom between the letter "A" of Xperia and Option botton...
when i touch the screen its come after few second it disappear....
and another white spot shown at the screen menu button (screen home button)...the spot is glowing...when the screen is white..it's visible quite clearly....
anyone facing those problem....should i go to the service centre...here in India they take more than 1 month...
i dont know what to do....
Martha-
I'm a bit confused.
Is the black spot like a light that isn't working? So you notice when the option key lights up?
The white spot that shows up during moments when the screen is white? I'm not sure I understand this part.
In the end, it's up to you to decide if you should visit a service center or not. Maybe you could take a photo of the issues and reply?
Let me know.
6 REPLIES 6
Martha-
I'm a bit confused.
Let me know.
Thank you for your attention.....the white spot is always there....when the screen is white it is quite visible, otherwise not so much....
And the black dot is coming when I touch the screen or scroling....
I have checked my friend's mobile the black dot is coming to his mobile too...not the white spot...
gcs94
Same here...
Happen to my old white mini pro and my new black mini pro...
Qupo
I got the black spot too but not the white spot
It's not very visible at first but when scrolling in browser or something white, it become more noticeable
The spot only become black(or dim?) when i scroll.
I've open up the service mode and nothing happen in the display test!
Now i'm confused, is it a hardware or software problem?
I think it is a hardware issue...
i have taken screenshot at that perticuler time but the snapshot is showing nothing..
Even in my laptop the snspshot is clear without any dot....
I have taken a picture in my digital camera...i can show you the spot...check the picture
Qupo
But my blackspot will fade out itself, weird 😕
And the white spot is too hard to notice, i don't think i have it....
Let's hope it's only a display driver issue Slightly_frowning_Face
