What is the purpose of 'being discoverable for 120 seconds'? When I turn on bluetooth, by default it is not discoverable. That is good. However when I make is discoverable, I expect to be discoverable until I turn the bluetooth off. Any idea?
I think It's a feature... So that if you forgot to turn off the bluetooth it will not stay discoverable and no one can connect to your phone without you knowing it.
ok thanks
No problem^^
