Just purchased Xperia X8 ... it will connect to my Peugeot 207cc but can't access directory or make calls via car ... my previous phone ... Vivaz worked perfectly ? Any suggestions ? I'm very disappointed !
Xperia active – ST17i
Xperia arc – LT15i
Xperia mini – ST15i
Xperia mini pro – SK17i
Xperia neo – MT15i
Xperia PLAY – R800i
Xperia pro – MK16i
Xperia ray – ST18i
Xperia X10 – X10i
Xperia X10 mini – E10i
Xperia X10 mini pro – U20i
Xperia X8 – E15i
Sony Ericsson Mix Walkman – WT13i
Sony Ericsson txt – CK13i
Sony Ericsson txt pro – CK15i
W8 Walkman – E16i
Walkman WT18i
Vivaz - U5i
how are you trying to sync the phone w/ your car?
Have connected via Bluetooth ... both car and phone recognise each other and connect but won't show directory ... only 'Call list' which when clicked onto via car does nothing.
I don't think its the phone but the car itself
http://www.peugeot.co.uk/showrooms/connect/bluetooth-compatibility/
Mmm .... How annoying !!
Have looked at lists .... but can't see Xperia or Vivaz ... should I be looking for a model number ?? If so not sure what I should be looking for ?
Thank you for your help,
Adele
Xperia arc – LT15i
Xperia mini – ST15i
Xperia neo – MT15i
Xperia PLAY – R800i
Xperia pro – MK16i
Xperia ray – ST18i
Xperia X10 – X10i
Xperia X8 – E15i
W8 Walkman – E16i
Walkman WT18i
Vivaz - U5i
Thank you ... as suspected it's not on any of the lists ... However the connection does allow me to receive calls in car and displays info ... and connects via car if I call on handset so guess that's fine really !! Will know to check out this stuff next time I get a new phone !
Thanks again !
no problem
