Connecting usb printer to Xperia S
Ben
Can any one help me on how to connect usb printer to Xperia S,
Thanks & Regards.
ganeshmanjare
Use apps like Printershare or printhand through which using usb otg cable u can print the documents,photos etc.
8 REPLIES 8
de-es
I highly doubt usb printers are supported. You'd have to flash a custom ROM with such support imho. Try asking on http://forum.xda-developers.com/
Thommo
Genius
Try an app like Cloud Print found here https://play.google.com/store/apps/details?id=com.pauloslf.cloudprint&hl=en
This allows you to print via your Pc or if your Printer is wireless and setup in that way then your Pc does not need to be on
Ben
Thank You Slightly_smiling_Face
Ben
ganeshmanjare
Ben
Thanks man Printhand really worked out.:-)
rosesophos
Actually, I was also facing sich kind of issues in connecting
ellajonson98
Recently I bought a Dell printer but when I tried to connect the USB printer to Xperia s it shows an error dell error code 2000-0333, I really have no idea how to remove this error so I want a proper solution how to remove this error as soon as possible.
