I lost my original charger that came along with the box. So I purchased a Sony Ericsson X10 Charger charger with EC 700 USB cable from open market. But even after plugging it for two hours, not even one % charging. :smileycry:Anyone please suggest which are the chargers that support Xperia Ion quick charging? How about EP850 charger with EC 801 cable? These models are capable of quick charging ? What was the model number of original Xperia Ion charger and cable? Please help.:smileycry: Kudos assured
You can use quick charger EP850/EP851 with the USB cable EC801/EC802. Or you can use quick charger EP880/EP881 with USB cable EC801/EC802
You can use the Xperia Z, or Z1 or T or etc etc's chargers
Be careful not to use higher voltage adapters.If the amperage is higher no problem.
