cedar calling problem
my SE cedar hangs up while calling or during any network related activity.
this doesn't happen when other sim cards are used.
when i put my sim card in other's phone and then put back in my phone,it starts working.
Is this a sim card problem or i need a software update?
I tried software update with PC companion and also with update service.But its saying 'no new software update' even in case of repair mode.
so if i need an update how to do it?
or i should change the sim card?
Please help me.
Dr_Chris
I suggest you clean the contacts on both the SIM card and the SIM card slot (in the phone) and see if that helps.If not, try a master reset and failing that, request another SIM card from your network.
3 REPLIES 3
Dr_Chris
problem solved
i have replaced my old sim card with anew one
no troubles now
Dr_Chris
That's great!
