Hi guys ,
i am facing this problem for last two days. I tried restarting phone and also factory resetting. No use..still the same. Please help guys..:-(
Thanks for your reply...this same problem was mentioned in of the similar posts...i tried the same..now its working fine... I only did one thing..Factory Reset
Have you tested ringer in your service menu? If not try opening your dialer and keying in
*#*#7378423#*#* (spells service in text terms)
Then select service tests and try speaker and vibrator and see what happens.
Let us know.
i face almost the same issue
when i keep the vibration alaways on in the settings for few times the phone vibrates in silent mode
but after some time the phone shows no vibration in silent mode.
when i check in sonds the settings for vibration changes to never automatically
what should i do
but in the above said method the phone rings and vibrates
pls help
thanks
Cannot hear ringtone for incoming call on Xperia xa ultra dual sim
