Can Xperia S Weather Widget be installed in Neo V with ICS. If yes, Does it requires rooted Neo V or it installs in unrooted Neo V?
Just normal installaton.
like any other app
send to your mobile in an empty folder./... install every app one by one.. using any file manager
i downloaded it and i replaced the old one but when i choose it form the widget list it doesn't show anything :S....how can i restore my old one
thats odd... try restarting your phone
and check again properly
To remove it
settings >app > downloaded > weather widget > uninstall update
i did nth shows ....maybe i have to root my phone ?
Hmmmmmm i think you will have to
You will void your warranty after rooting..
but if you decide then there is a new world awaiting for your device
You will get the whole xperia s , its homescreen and just everytihng
i guess i will get xperia s because neo is lagging alot although its empty ,,,,,thanks for your help
Then better to go for any NXT and not arc s...
either Xperia P or U or S...
now its not worth going for arc s as you will get a dual core with much better technology that arc at the price of Arc s
thank u Nabeel it worked (the widgets) i had to install the home widget first ...thanks again
i'll try if this will work on unrooted ics. :smileygrin: and i will update after.
ooopps. the weather widget can be installed in ics but it won't work. i'm stucked at setting the weather widget. i can't press the location and the done button.
Message was edited by: cpu_usage
Its only for GB
not ICS
