Can Xperia S weather widget be installed in Neo V
session
Can Xperia S Weather Widget be installed in Neo V with ICS. If yes, Does it requires rooted Neo V or it installs in unrooted Neo V?
37 REPLIES 37
session
Music Player and Music Player are working fine in Neo V ICS... but Sound Enhancements is not working when opened i get a message Unfortunately, Sound Enhancements has stopped.
I think we have to wait for more widgets when Xperia S ICS release
cooldudesrg
Dear Nabeel,
I downloaded the packages given by you and found different .apk files in it and so i copied the Xperia S weather widget .apk file from my laptop to my Neo V Micro SD card and tried to install it using app installer after that the new waether widget shows could not load...
Am i missing any thing please do explain to solve the issue.
Regards,
Raja.
session
Weather Widget is not working in ICS.....
Should have to wait till Xperia S ICS release and some extract apks from it... and then also there is no guarantee that it will work.
Nabeel
There are many apps of Xperia S which need mobile to be rooted for example weather widget
Morover as session said it won't work with ICS ( if you are on ICS )
karanstyle
Is it for GB or ICS 4.0.4(I'm using "Xperia Neo ICS" & New to Android)
Nabeel
It's for gingerbread
For ics here you go
http://forum.xda-developers.com/showthread.php?t=1601498
Xpeeria-Pro-Use
Anything similar for Xperia Pro (without root)?
Nabeel
i gues you could only install music player on your phone, without root that too with limited functionality
