Can't find system alarm
I'm trying to access my alarm from the clock widget and keep getting an error stating "system alarm cannot be found." How do I fix this? This happends when i'm using GO Launcher, i try reset factory settings but it's same. When i'm using default xperia launcher and when i tap on clock widget i open alarm settings. I try servel clock widgets and it's same problem with GO LAuncher. Why is that?
Nabeel
Strange problem is that. Thinking_Face Neutral_Face Anguished_Face
Backup everything as it will erase all data on phone
Update/Repair your phone via PCC OR SUS
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
Both the links are same
8 REPLIES 8
Nabeel
                  or
when i done this above do i must done and this or is the same thing like above ?
Nabeel
just one... either sus or pcc.... not both
ok, now i'm updating phone, i'll let you know is it work after i finish with all.
btw thnx
ok, i done all that, but still when i'm using go launcher and tap on clock widget i get this "system alarm cannot be found" .
Nabeel
Can you use it normally now ?
Leave go launcher , its not fully compatible with your xperia s,, i have seens many users complaining about it..
yes i can. when i use default xperia launcher is working normaly as is before, but seems like u say it's problem with go launcher.
Nabeel
Yes.... its problem with go launcher....
