I disabled from the camera settings the QuickButton, as camera goes on a quite easelly from the login screen of 4.3
The end result is that I cannor get camera on. The camera button doesn't work nor I cannot find the camera app 😞
I do get camera working with the additional app but via those cannot get into original settings.
I _reallty_ would not like to reinstall the whole FW, any hints how to get access to the standard camera app ???
You are correct, the Camera application is there but with the of phone's set-up language (in my case 'Kamera'). That's why I couldn't find it amoung the others.
Thanks
There should be an app called camera,the same like you would quick launch it.From there,enable quick launch.
so simple
never panic
its the world created by humans and we bettr know how to amend things
Under the All
There is 'Xperia camera extension' and the 'Camera Common' & 'Camera extension'
The only option seems to disable i.e. they are available
Though I found the solution! Search Application-Camera ; the Camera started and I was able to solve the problem. Still I have no Camera Icon available on the All Applications view but with camera button it starts???
If you scroll down isn't it there?
Great.
This was the best solution and very easy too. Go to
Settings
Apps
'All' or there maybe a tab named 'Disabled'
Find the 'Camera' app and click 'Enable'.
Chances are you disabled the camera app when you were trying to make some space on your phone.
