Bugs Jelly Bean
jonatan24
Bugs Jelly Bean
Hi!
the wait has been worth it. Sony has worked hard to show their work.
You notice a big change, especially regarding fluency device.
The only bug I've noticed, and large, is that every time I turn on my phone, I have to manually select my coverage. search mode is automatic, therefore, that is not a problem, and the problem is obviously in this version.
For me it's no trouble every time you turn the phone, manually select my coverage, but for some users, maybe it is. anyone have this problem? or other?
I hope it gets fixed, thank you very much.
19 REPLIES 19
Skynet1
Power management does not shows the estimated time correctly.I have 86% battery and it shows 5 hrs standby even if I charge to 100% it shows the same thing:smileysad:
Er_Vaibhav
Hi, the colour of notification LED has changed to default(white) after upgarding to JB. Before upgrading it was different for message/calls/whatsapp etc. notifications.
Can anyone tell me if I can change the colour of notification LED(in whatsapp option is there but not in message/call)..?
florenzgonzales
bro, did you manually install jellybean on your phone?
Er_Vaibhav
I upgraded it through PCC after getting the notification for available upgrade.
teco
Try "light manager" from Google play, it gives you all the options for led notifications colors.
Vishwas
Updated to JB 2 days ago though everything is running smooth Slightly_smiling_Face but then realized that internet is not working at all when Stamina mode is on :smileycry:, quite irritating though no 1 msged me on wats app, hangout until I connected to WIFI then msgs started flooding :smileyplain:. Hence turned the stamina mode off but still no good :smileysad:, please tell me what I should do now?
Am using GPRS as the Vodafone having issues with 3G, the send/receive data arrow keeps juggling but no data received and every now then a flash error throws up saying could not connect to internet. I have the right settings and it works fine sometime but then issue starts suddenly Angry_Face
feds
using stamina mode would let you connect to strong signals only. It will notify you that stamina mode is avoiding poor connections
jackxperiaP
factory reset and then install ur internet settings again from settings>xperia>install internet settings
Vishwas
ok fixied it by simple steps: settings > more > mobile networks > access point names > selected VDF Mobile Connect and that did it Slightly_smiling_Face
jackxperiaP
