bluetooth headset compatibility
bokyo
I was using a Jabra clipper BT headset for awhile with my xperia play. But when i upraded my phone to xperia acro s, the phone cannot detect the jabra clipper. Is it totally incompatible with xperia acro S?
Johan
If you had this headset paired previously you probably need to put the it in pairing mode before any other device can locate it. Check if you have any users guide for your headset and if it mentions anything about how to put it in pairing mode.
2 REPLIES 2
Johan
bokyo
That did the trick. Thanks Johan! Slightly_smiling_Face
