Battery running out soon
I bought Xperia ray yesterday. I have reacharged it fully. But its running out soon. Mostly 1 point going down for a minute.
Its seems like it survive only  2 hrs... plzz... help.....
Also remember that there are settings and/or apps that will drain your battery
1) taskillers
2) battery/juice defenders
3) antiviruses/mcafees
10 REPLIES 10
backup everything and then repair it with Update Service
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1315209439/Update_Service_Setup-2.11.9.6.exe
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
and also
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
or
How to install it
You need to
Contacts
open your phonebook
on your computer
Apps
SMS/MMS
or your SMS use
Call Logs
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
1) taskillers
Download this app Power Control
https://market.android.com/details?id=at.abraxas.powerwidget.free&feature=more_from_developer#?t=W25....
Some functions in your phone may consume more battery, leading to a shorter battery time. In order to maximise your battery performance, make sure you switch off functions you don't use, such as Bluetooth™, and lower the screen brightness.
To access the battery usage menu:
From the Home screen, tap the Application screens icon.
Find and tap Settings > About phone > Battery use to see what has been using the battery.
To add the Status switch widget to the Home screen:
From the Home screen, press the Menu key.
Tap Add > Widgets.
Select the Status switch widget.
To add the Data traffic widget to the Home screen:
Tap Add > Widgets.
Select the Data traffic widget. You can now turn on and off your data connections more easily.
To adjust the screen brightness:
Find and tap Settings > Display > Brightness.
To decrease the screen brightness, drag the slider to the left.
Tap OK.
To turn off all data traffic over mobile networks:
Find and tap Settings > Wireless & networks > Mobile networks.
Unmark the Data enabled checkbox.
slimshaddy
Hero
settings > wireless and networks > mobile networks > network mode > gsm only..
I found that display is eating the battery power... I reduced brightness to nearly 40.... but still its showing its usage as 75%.... and when the brightness was near 80 its showed same 75%...
plz advice.
turn off the bravia engine, screen timeout
also charge your phone 100% turn it off -> on -> now use your phone as normally you would, and wait until it reaches 10% battery left, go to settings -> about phone -> battery use
take screenshots of everything there
and either take screenshots or copy how long was each item on the list on (hours, minutes)
slimshaddy
Hero
i agree with uliwooly.
